Hello, can’t seem to get my SanDisk 16GB MSD card to insert . . . card doesn’t seem to engaged my V2 Cam. I did have it unpluged at the time.
Here’s how to insert the MicroSD card in a Wyze Cam
https://support.wyzecam.com/hc/en-us/articles/360022500271&?section=installing-microsd
Thanks for the reply.
I’ve been inserting (after formatted) it in the correct orientation with it unplugged. But, when you insert a card in a reader on any device it catches, then you have to push it again to release or eject it. Well, the Micro SD Card does not catch when I insert it in the camera.
Any thoughts,
You may need to use the tip of a narrow object (butter knife, screw driver, etc.) to carefully push the SD card into the slot for it to engage the card slot lock.
Yep, that did it!
I tried that earlier but did not get too agressive for fear of damaging the camera. I went back and you were right on target.
Thanks again, as usual you guys are the best.
Oh, by the way, I’m having cool whip on my humble pie! Ha
Thank you DPR
My pleasure! ![]()
