V3 won’t recognize my new SD card so I wanted to eject it, but it won’t come out
Any suggestions?
The cards usually come out if you just push them in a little with a finger nail or a small, narrow flat object then they will pop out a little. Or you can try a pair of small tweezers? You didn’t insert it upside down did you ? ![]()
Tried pushing, tried tweezers. It is so far in there I can’t get to it. I may have put it in upside down. my bad
If you do an Internet search there are many methods suggested. Go to browser and type : Remove jammed micro SD card. There are some you tube videos also available.
Thanks, I’ll give that a try
