How to determine which spotlight Control setting is active?
Would it be in white box or within the gray box?
Also, how do I sync my spotlight with motion dection- I am not using subscriptions?
thanks
If you’re asking about this screen:
The values on white background are the current settings.
Set “SPOTLIGHT CONTROL” to “Auto”
You don’t need to subscribe for this to work.
