V4 Spotlight settings
Automatic setting for spotlight doesn’t stay set. Turn on spotlight with motion setting is gone. Is this a bug or is Wyze forcing you to get cam plus?
If you could mention which app and firmware versions you’re using, that might be helpful. What you’re describing appears to be related to an issue raised in the latest Cam v4 firmware topic, and the Release Notes do mention an update to the spotlight control, though I wouldn’t expect that to completely disable an existing setting. I think you’re probably experiencing a bug.
App v3.1.0 (564)
Firmware 4.52.8.0648
I am having the same issue one of the cameras has the controls the other one does not.
iOS app 3.1.0.6 on iPad
Has a setting for all motion or just smart detections on both
iOS app 2.50.9 on iPhone
I have the exact same issue. Multiple v4 cameras, all on the same latest firmware (4.52.8. 0648) but only one has the All Motion Events and Timer options and is the only one where Spotlight Control + Auto stays enabled.
Coincidentally, it’s also the newest one AND the only one I bought in the US (vs Canada).
Just installed another “new” v4 (from the US) and also has the All Motion Events and Timer options and the Spotlight Control + Auto stays enabled.
In other words, it seems like it’s more then just a firmware thing. Possibly physical differences in v4 models.
My issue was fixed for all cameras with the lastest software update. I see they have them in black now and I have the grey ones.
