How to change time in Watch 47
I cannot find anywhere how to change the time.
it mirrors the time on your device. there’s no controls on the phone to change time.
The watch clock is controlled by your phone under settings
My wife and I have identical Wyze 47 watches and identical apple cell phones with identical settings in the Wyze app. My phone changed yesterday with the time change, hers did NOT change but her cell phone did. I’ve turned it off and on, restarted, etc, no change. Any other ideas?
Did you sync it using the app?
Yes. I deleted the watch and re-installed it. Works now
All I did was power cycle both items and it worked just fine
My watch didn’t automatically change with daylight savings time either. I rebooted it and it changed.
U have the model47 and it was correct when i got up @ 0600
