Here is a wild question. Is it possible to change the dash cam soft ware that Mfg. installed.
On a cell phone you can down load an app, like Dailyroads and turn the phone into a dash
cam ( the app is from google play store). I was wondering if there is a way to download the
app to a dash cam and us Dailyroads dash cam instead of the one the Mfg installed. This way you would have GPS and wifi on a cam. I know you can buy cam with this on them but why cant you just change the program. In other words can you wipe out memory and install something else? Thanks
The Wyze cam does not have a GPS receiver in it.
