How do I download just a video or picture
I need to download videos to pass on to the police and my landlord. I don’t think I want to share all my account so how do I isolate just one video and/or picture to download and then pass on to others.
Since you tagged this with outdoor-cam, I’m assuming your videos are stored in the cloud (events tab at bottom of app). In this case you can use the little download button (looks like a down arrow) on the event. Click the event video, then that button will appear as an overlay when tapping the video.
Worked perfectly, thanks!
I want to save BIRD videos from my feeder to my computer. Using the wyze cameras feature on the browser. Can they add a link to download form the cloud to PC? I have 20tb of storage and I hate downloading to my PHONE then sending it again to the PC.
Not sure if Wyze Web View lets you download videos (I think they’re lower resolution anyway so probably wouldn’t be ideal), plus it requires a subscription.
If you’re using Windows 10 or later you can install “Microsoft Phone Link”, which may allow you to download direct to the PC. There are also Android emulators for the PC where you can load up the Wyze app right on your PC. Unfortunately Wyze does not have any native app for the computer.
Easiest option may be to just enable synch on your photos app and then install or access them on your PC that way. For example when you enable synch on Google Photos they have a synch app you can put on your PC that will give you direct access to those files. I’m guessing Apple and Samsung and others have similar.
