My cam pan v3 doesn’t detect motion hotline. I have track and pan scan enabled. It doesn’t seem to move as far as it should. I have way points set as far as possible.
Providing more detail about what you hope to accomplish might be helpful. More specifics about your settings might help, too.
After trying Track Motion and Pan Scan both enabled at the same time, I found that using them together was counterproductive to my expectation, so I’ve left the latter feature disabled, though I do use Waypoints for convenience when peeking in on the Live Stream.
