Pan V3 Scan & Track
Is there a way to get the Cam Pan V3 to start tracking people as it’s scanning across back and forth?
Ya know…it will stop scanning and start following the person as an event.
Or, is it one or the other?
Yes. If you have the Pan Scan feature enabled and the Track Motion feature enabled, the cam will scan per the default or custom waypoints. When it encounters a moving object that meets the Sensitivity threshold set in the settings, it will then track that motion until it stops or exits the FOV. The cam will then return to it’s Pan Scan routine.
Thank you man
In my testing, though not installed where I want to put it, it seemed that it was either/or.
Cheers!
