Cam pan v3 not panning
Set up my cameras and for some reason my interior camera is not panning like it should. I’ve set up waypoints, they dont work. Reverted to default waypoints, no panning. Its not even paning towards movement. The one i have outside is moving all over because its pouring rain and its deciding to catch every drop. Not sure whats going on.
Make sure you have Pan Scan and / or Motion Tracking turned on.
I have not seen a setting to turn pan scaning on or off. The pan scaning in the motor function setting just takes you to way points. I do have motion yracking on. Doesnt fix the issue unfortunately.
Swipe the control bar under the live stream view to the left to see additional control features:
I was wondering how to access the extra options from the playback screen, thank you! I will see if this helps. I had been doing all of my settings from the main detection and motor function setting menus.
