Hooking up Wyze cam to fire tv with tiny cam pro problems
Hi everyone, I am trying to hook up one of my Wyze cams up to a new fire tv and I’m using tiny cam pro. I get as far as getting signing into Wyze and get the code and entering it when I hit next button nothing happens. Can someone help me? Thanks
Tiny Cam is a 3rd party program not affiliated with Wyze, I believe they have a reddit forum and some contact info on their page.
Apparently if you set up the cams in the alexa app on your phone/tablet/whatever you can then view them on the TV via the fire stick, that might be a better setup.
Latest version (Dec 2024) has Wyze login bug fix.
Btw, you don’t need Tinycam to view your cameras on the FireTv.
Simply install the Alexa skill and then “voice” command your tv to show the intended camera.
Yeah but this only shows one camera. How can we see multiple cams? It works fine on an echo show .. why not a fire tv??
Same problem here .. ever find a fix for logging in??
Try putting the cams into a cam group and seeing if it will let you ask for that (not sure if it will or not).
If not, then tiny cam is your best bet for viewing multiple cams at the same time (or an android TV box, or tablet connected to the TV, etc).
Update to the latest version of tiny cam.
I did try the group thing. It just asks me which one from the group I want to see. “It” being Alexa. lol!
I can’t get tiny cam to let me move past the Wyze security code screen. It lets me enter the code but that’s it. I’ve tried the remote and the fire app remote on my phone. Idk if it’s a Wyze thing or a tiny cam thing. Uninstalled and reinstalled as well.
Thanks for your advice!
As far as I can tell .. it is updated. I have no other options. I’ll look again tho.
Yeah I just played around with it, neither the wyze cam group or a group in alexa will let you show multiple at the same time. So with the alexa skill on fireTV at least it is a single cam only. My phone also asks “which cam”.
Strange that you can’t listen to audio there either, but can do it on the phone (the only other alexa device I have). My 1080P cams are clear on the TV, but my v4 (2.5K) seems blurry even when I step it down to 1080P in the app (both on Fire stick and on my phone via alexa app).
So I guess it has some limitations/bugs.
I GOT IT TO WORK!! I had to disable the 2FA in the Wyze app.
