Just curious to know what sort of systems people are using.
Does anyone use just one product line and control app ie Wyze only?
Or a single system married to what ever assistant product?
Or are you using multiple products lines in a hodgepodge addressing your perceived desires as you tool along in this infantile industry (raising 2 hands)?
Or are you completely insane and using a hodgepodge of devices/apps with a frankenstein of assistants a la google, alexa homekit/siri etc, because, well, you are as 1st stated, insane?
Where do you fall & what do you use?
In my case, 1 overlord (alexa, tho it is likely as intrusive or worse than google which I despise) with a farking bastaged system comprised of wyze, arlo, sonoff, shelly, tplink, wiz, teckin, feit, august, amazon, dilisens, zentec, sonos, & holmes/wemo.
As a result I have august, smart life, tuya, ewelink, tplink, sonos, wiz, wemo, & sonos apps to content with and NOTHING that works with everything.
Ifttt aint enough (missed by miles), stringify is dead (was promising), yonomi is useless (slower than dirt to add to the library and so so so limited!).
Anyone using a consolidating interface that marries most of their techs together?
