Help With Poop!
Last night, my dog pooped on the floor and the vacuum rolled over it and got stuck. I am unable to get all of the poop out of the wheel treads and wheel cavities.
Any Ideas?
Is there a way to remove the wheels to clean them?
You might have better luck getting it off with some kind of brush after it is totally dry
First, remove the wheel. Second, clean the wheel
But how do I remove the wheel? I don’t want to break it and I’m afraid of not being able to put it back together.
I sadly just threw our vacuum away as we had a dog poop issue. It was literally everywhere. No way I trust being able to clean the insides of the vacuum adequately. I can’t bring myself to buying another one of these in fear this will happen again. As much as I loved it and love all the wyze products (and I’ve bought most of them) unless it has some way to not spread it everywhere and be 100% cleaned I’m out.
I would try taking you apart to clean it up, you have nothing to lose if you can’t get it back together, but you can try
That is where I am at now. Found a teardown walkthrough on YT. The last thing I have is to try and separate the wheel rubber from the hub. Seems to be pressed in between two halves so I guess I get to pick it out with a screwdriver. At least I got the wheel well removed so I can be washed.
If it doesn’t work when I put it back together I guess I go shopping.
Best of luck to you .
it could be beneficial to other people if you could post a link to where you found the teardown walkthrough :grinning:
