Help! No notifications on SOME of my V3 cams
I have 13 V3 cameras. The ones I have mounted outdoors on porches will push AI detection notifications to my Android phone via the Wyze app.
My problem is with 3 of the V3 cameras that I have mounted indoors. These cameras detect persons reliably, but WILL NOT push the notifications for these detections, so I never know these events have happened until I decide to look at the app.
The detection, event recording, and notification settings and firmware versions (latest available - beta) on all cameras are identical.
Any suggestions? I have already reset all of the cameras, turned off and then back on all notification, event recording, and detection settings. I even removed the affected cameras from the Cam Plus Unlimited plan and then re-added them after force-stopping the app and clearing the cache. Nothing seems to help. :expressionless:
Any ideas?
Thanks. I may have to go that route. I was hoping to avoid driving back over there this week again, but I might as well give it a try.
Much appreciated @Rulwiz
