Hacked System
Anyone else been system Hacked? I’ve changed username and passwords regularly but they still get in. Super sick of it. HEEEEELP Please…
What in particular is happening that makes you believe you are hacked?
If you turn on 2 Factor Authentication (I recommend doing this with an authenticator app because then it will be impossible for them to get it through your email or a text message) and change your password to something you’ve NEVER used before then it’s extremely unlikely anyone can hack you.
Still, if you believe this may be the case, you need to email security@wyze.com from the same email address as your Wyze account and they will look into it for you.
If you feel you are being targeted by someone, consider changing your WiFi network SSID and password and don’t let visitors on your network. Maybe setup your cameras on a guest network with “Device Isolation” turned on.
Don’t share your cameras with any other account.
Make sure you aren’t using malware or lesser-known apps on your phone that might have malware on them.
