Now they’ve finally arrived and 8 of the 13 are deployed - 2 observations
Leak sensors should be able to be grouped, and have a single rule assigned for a group.
If ANY leak detected, turn on all sirens (in my case only WCO’s are available), which leads to me next point:
The sense hub should be a siren for the leak sensors, this is simple logic.
IMO, all cams regardless of type should be able to wail thru their speakers as alarms.
Seriously - water damage is the most costly damage you’re home or business can go through outside of the premises exploding from a gas leak.
