Google Home duck a duck
I just looked at my Google Home and it saw my DUO cam. I clicked on it, it showed me my porch for a few seconds, then a blank screen with “something went wrong”. Is Wyze still not working properly with Google Home (much less HomeAssistant)
Sorry you’re dealing with this, a blank screen after a few seconds of video is a frustrating way for it to fail. I can’t say whether Wyze has fixed the Google Home side yet, but since it showed your porch first, the camera and its connection may be fine and the hiccup could be in the link to Google. I’d try unlinking Wyze in the Google Home app, linking it again, and checking whether the Duo shows live view after it syncs back.
Not sure what the cause is for the timing out. My cams livestream in the Google Home app continuously on my Android phone. I just did a 5 min. live cycle with 1 of my duos. I have a mesh router wifi system with a separate 2.4 iot band.
Sounds like a possible Google Android vs Apple IOS issue. Although Wyze cloud via AWS is the connecting point.
