Good afternoon, is it possible to see the cameras on a TV screen
Welcome to the community.
If you are using a Google Chrome/TV device or an Alexa Fire TV type of device with your TV, then you should be able to ask Google or Alexa to stream the camera you want on the TV device (whatever it is named).
Also, if you have Cam Plus on your cameras, you can open a browser on your TV and
log in to your Wyze account at https://view.wyze.com/ to view your cameras there, including multiple cameras at a time.
Another thing people do is get the App called Timy Cam or Tiny Cam Pro, and then you can view a lot of cameras all at the same time that way. It is usually available through the Amazon App Store or The Google Play Store, or you can potentially side-load it onto the TV OS.
Those are the main ways people view their Wyze cameras on the TV, but there are others that get a little more complex that you can do which involve things like RTSP, etc.
Thank you very much for your help.
You can also use your Android tablet or cell phone to “cast” or “mirror” what you are viewing on those devices onto your SmartTV. Go to “Settings” on the device you are going to “cast” from and select “Connected Devices” and then select “Connection Preferences” and finally select “Cast.”
Oh yes! Great suggestion!
