Garage door won't open or close under Alexa
I’ve installed the garage door opener. The Wyze app sees it and it says it calibrated correctly. On the video there is a little red box around the QR code so I assume the controller sees it. However, there’s no open or close garage door status on the Wyze app. Does this require Cam Plus service? I can open and close the garage door fine using the Wyze app.
My Alexa app with the Wyze skill sees the garage door and it appears in my Alexa devices. However, it says the “Device is unresponsive.” on the Alexa device list. When I try to open or close the garage door via Alexa, it asks me for my pin, then says it is opening or closing the garage door. However, it fails with Alexa saying “Your hardware device is not responding. Please check your third-party garage door app.”
I have read here that Alexa and Wyze are currently having problems working together. My question is whether my problem is with the Alexa/Wyze issue or else something I am doing wrong. Any insight will be appreciated.
Camera firmware version: 4.36.14.3497
Garage door firmware version: 0.10.0.21
