Please provide Wyze Garage Door Controller to Amazon Alexa integration.
[Mod Edit]: Title, tags and request text modified to enhance search clarity.
garage door controller with Alexa
When with We be able to open and close the door with alexa?
PLEASE SEARCH #wishlist and #roadmap and read the How to Use the Wishlist BEFORE POSTING. If your submission is approved, don’t forget to VOTE for it.
I just finished installing the Wyze garage door controller and it works great from the app. Would love to know when the Alexa integration will be available. Can someone from Wyze comment to let us know? Thanks!
Garage Door Controller-Alexa timeframe
What’s the time frame for when I can say “Alexa, open the garage door?” Or add a sequence so that when I say “time for work” my lights go off and my garage door opens?
Just got finished setting mine up, and it works. But I want it to work with Alexa too.
Says I have to have a Pin Code, but no option to set it in Alexa for the opener, and then too the Camera portion of the Door Controller does not even show up in Alexa. I want to be able to look at my Echo Show see my garage door and tell Alexa to Open or Close it.
Found by one of the Wyze Discord members @tfmm. Thank you!
There appears to be a bug in the Alexa App, but this utility is available.
Open the Alexa App and Navigate to the the Garage Door Controller Device
Touch in the Area Where the Enable Toggle “Should be”.
You will be presented with the option to “Enable open by Voice”
Click Ok
Set your Voice Code Pin x2
And you are done
Great Find and thank you for sharing @tfmm!
