Future Outdoor WyzeCams ( Hopefully)
I wanted to start a thread hoping Wyzecam looks into the very near future for outdoor cameras. I will be in the market for some outdoor cameras for my home and business. Some thoughts on functionality for future products that I would like to see and keeping the low prices as they have already done for their indoor cameras would be the following:
  1. 1/2.5 inch, 8 megapixel sensor/ 4K wishful thinking.
  2. 8x digital zoom or higher.
  3. 1080p at 60 frames /sec H2.64 encoding.
  4. 130 digital wide-angle view or better.
  5. 6 or more LED high-power infrared for night vision.
  6. 2 way talk and listen.
  7. Status light on/off option.
  8. IP65 ratingfor outdoor usage (withstand dust/rain/snow).
  9. Magnet Mount w/weatherproof cable.
    10.Option for high SD card memory for better continuous recording.
    11.Micros-B Power cable.
    12.128-bit AES with TLS/SSL
  10. Wifi 802.11a/b/g/n/. 2.4GHZ and 5 GHz.
  11. Bluetooth Low energy.
  12. Google Home/Amazon Alexa support with Chromecast capability.
One function I would like to see in the indoor cameras as well as the future outdoor cameras (if they make this product), I would like to have the app deduct your proximity based on your GPS location. This would allow the cameras to be turned off when you are at home. Or setup a schedule to when the cameras can be turned on/off based on a scheduled set within the app. Similar to how we have for the notifications.
There is an outdoor camera thread in the “product roadmap” section. be sure to check there. When we are able to share more information, we will post there first.
