Hi Guys,
Would you have any plan for a wyze cam outdoor ?
Just the base wyzecam but just weatherproof would already be a very good asset.
Hi Guys,
It’s a frequent request, so hopefully Wyze has something in the works ![]()
In the mean time, people have had success mounting the cameras outdoors under cover through winter and summer (so far).
There are also some outdoor case/mounts you can find on Amazon. And folks have come up with some innovative clear box solutions you can find if you search here on the forum.
Thanks a lot Rick0, sorry to have missed the previous post on that topic.
I’ll check as well if I can find a topic on Jeedom integration
Have a very nice day.
The real issue is having a self-contained power supply for the cam.
Outdoor mounts are easy. Getting power to the cams, not so much!
My two regular ole’ wyze $20 cameras just made it through a very rough upper peninsula of Michigan winter. I bought these two very inexpensive mounts on Amazon https://www.amazon.com/dp/B07G732B9J/ref=cm_sw_r_cp_apa_i_Xu9LCbP64CTCE
My cameras are under an eve with no overhead water exposure. Sd micro card in them as well. They preformed like Champs. Zero issues all winter long.
