I’m about to bite the bullet and purchase a floodlight and the HMS kit. I’m a bit worried though, because it seems like I might not be able to program the floodlight siren to activate when the alarm is triggered by an entry sensor or motion in Away Mode. Is this true?
Is there a way to activate and deactivate that rule automatically based on my location or if the system is armed? Maybe even with a slight delay?
Unfortunately, not that I see.
Easiest way is to make shortcuts to the rule. Allowing you to turn on and off. Or as shown in the above example set an active time.
