Does anyone have a template so I can cut a lighting filter and put over the Floods? I really hate the cool white light of this product and prefer warm LED’s, so I figured if I used an orange filter it should be about right in color. But it’s kind of hard to trace out a template because of the overhang edges on the floods, and because I don’t want to have to take the floodlight down from where I have it mounted on my house.
No template but I have the Remove before use sticker in front of me the dimensions are
Width 6.5cm
Height 6.5cm
Corner Radius 1.5cm
Might be difficult to cut due to the rounded corners, without a template. I’ll look for my box and see if I saved those flood stickers, then I have a template. Thanks for reminding me about the stickers!
For sure. Tried to build one but got caught in meetings all day. If you don’t have the stickers I’ll see if I can whip one up.
Just checked the box, I must have thrown them away as they aren’t in the box.
I agree! Who want’s cool white LED’s anymore? Makes you feel like you’re in a hospital.
Too many of the outside garage lights in my neighborhood have those cool white LED lights and it’s so annoying when you go for a walk at night, eye blinding. Then my City changed the street lights from a nice yellowish non glaring light to super bright LED’s that are more white. This made things even worse, at least for me. Softer white light works for me, probably why I love being around a fireplace.
Just wondering if you were ever able to help me with this. I completely forgot about this project of mine until I went outside those bright cool white floods lit me up. I really wish they made these with warm white LED’s or maybe even color LED’s that we could customize.
Thanks for the reminder.
Ok so this was probably more of a challenge than I thought… even though it shouldn’t have been, and I hope this works but this link is a file that I made in cm with halves you should be able to download and cut out the pattern as shown here (Some precise drawing and kindergarten marker
@WyzeHongfei
How I made it using the Remove Before use sticker that came on the Floodlight.
Did you give this a try?
I haven’t been able to get it printed out.
Really wish Wyze used warm LED’s in the Floodlight or maybe even offered filters for it or better yet used color changeable LED’s. I absolutely can’t stand cool white LED’s.
I am actually the opposite and prefer cool white, especially indoors. The amber of warm whites change the colors of paint to much for my liking.
And for outdoors it seems brighter and more matter of fact , where with the flood light I am not looking for a gentle “hey there is some light on you” and more of a You are getting blinded for a reason ![]()
A warmer light reminds me of a fireplace and is soothing. When I walk my neighborhood at night the houses with warm porch lighting make the area look nice. But those with the cool white lights ruins it. Cool white reminds me of a hospital and just hurts my eyes. I can handle something in-between. There are many instances when I would want a bright cool white light, like in my garage if I’m working on something. But I don’t want my outside porch lights or floodlights that way.
Here you go @Resist 4 years later and your request has been filled
About freaking time! Do they have the filters for all versions of the floodlight because my V1 floodlight is having issues and I’m going to replace it with a Pro version I bought when it first came out but never installed. I want filters for it.
Per the offering just the v1 and v2, not the pro at this time.
Well that doesn’t help me and it seems odd they won’t sell filters for their Pro version. Isn’t that a better product than their V1 and V2?.
I will be removing my V1 Floodlight because as I said it’s malfunctioning and way outside of the warranty. Just last night the floods were triggered on and it didn’t record anything. But it shouldn’t have come on anyway because it was turned off in the app.
