Hey #WYZE!
How about a shortcut added to the viewing screen for the Floodlight controls the same as you added a siren shortcut.
I see the one at the top of the screen. But one that we can turn it on/off and and set a day of the week and physical timer on and off.
You can set up a short cute rule , if that’s what you would like
On the home tab , top left plus sign , add rule , choose short cut , and add the action “turn on floodlight” name your rule and it’ll show up on the top of your home tab . And when you click on it , it’ll turn on the floodlight so you don’t have to open the v3 live feed and have to click on the floodlight icon for it to turn on
I don’t have a flood light option. I have “Turn on add-on spotlight”.
Which to means the add in spotlight for the v3.
Doesn’t work for the flood light.
I just tried that way you explain just to see.
Do you have the floodlight or the spotlight ?
I assumed you have the floodlight , bc of the title…?
Is the v3 recognizing the floodlight ?
Open the v3 settings ., scroll down to Accessories > and click on that and besides floodlight is should say in green “installed” meaning it’s been recognized
Yes that’s correct green installed
Thank you.
In my rules I have the option for all accessories, even if I don’t have them installed. Can you send a screenshot of that page.
Your not able to scroll down?
Well I’ll be dang!!!
Now I feel stupid!!
Hahahaah
Yes I see it now!!
The list was so long I did t think about scrolling for more!
Thank you for your help!!!
Thank you.
Haha, glad you got it!
