Floodlights - Alexa
There needs to be a much simpler way to turn the flood light on and off. For example, if you were working outside and you need the light to stay on, you should be able to simply tell Alexa to turn the light on and then off when you are finished. Not everyone in my house will use the Wyze App.
Great idea, please use the #wishlist to suggest this, and make sure to vote on your own!
#wishlist
