Floodlight camera V1 is dead, dead
I have a floodlight camera V1 hardwired into my house’s soffit. Recently the camera went offline and I cant get the camera to do anything when I try to reset it to reinstall it in the app. I press the reset button on the camera itself and nothing at all flashes on the camera and there’s no voice prompt at all. Floodights are constantly on.
I’ve done these steps to remediate:
  • delete and reinstall app on my iPhone
  • cycled the circuit breaker on & off.
  • Reset router.
Anybody got any further ideas?
I wonder if the USB PCB powering the port is dead within the Floodlight.
You can try disconnecting the V3 camera from the Floodlight V1 and plug it with a USB cable into power adapter that is at least 5V 1 Amp to test. You will need a screwdriver to unmount the V3.
