Flood light Cam No timer option
When setting up motion sensor to turn on floodlight it’ll be useful to have a timed shut down so we don’t have the flood light running into the morning. E.g. motion detector turns on floodlight and we should be able to add a timer to turn off the flood light after 5/10/20 minutes.
I tried to add a 2nd motion event however there is no control that would sync to the motion detector not detecting motion to timed and shutdown thereafter.
I see that some user’s have posted screenshots of a timer option on floodlight but I don’t see this option on my floodcam!!!??? Different models?
Thanks rulwiz! My menu options are different it seems…
just found out it is hidden under Accessories >> Floodlight
The timer should really be located under the rule so we can configure different rules with the timer.
All the options for the floodlight are under accessories > floodlignt
