Rule to set Wyze Floodlight on doesn't light off
Hi, If I set a rule to start the light on my floodlight, how can I set it to automatically light off after a delay? (for now it stays on)
What are you wanting to accomplish with this? Just a shortcut to turn the light on for a few minutes while your doing something, or a schedule? The floodlight supports motion detection to turn the light on for X minutes if you want, otherwise you can use a scheduled rule to turn the light on and off at certain times.
You can also use the “Turn on floodlight for X minutes” rule action
No, not a shortcut, not a schedule, not manually.
I need a rule that activate the floodlight for 1 min when another cam detect motion.
Problem is the floodlight would stay on.
(edit) I found your “turn on floodlight for…” suggestion. Looks like it is what I need, thanks!
