Floodlight V2 - Rule allows turning on floodlight, but not turning it off
I created a rule so that whenever somebody is spotted on my doorbell camera my new V2 Floodlight turns on (because somebody can get to my door without being seen by the floodlight sensors)… but there seems to be no way to turn it off again after it turns on… not via the rule. We need a ‘Turn off after’ option or ‘Stay on for’ option so that the light will turn back off after a desired time.
I agree. I just installed a v2 floodlighf today and couldn’t believe that the floodlight stays on all day. I am testing using a rule to fix this but. I dont want it on all night. I want it on when motion is detected and then to turn off.
There is not a way to insert a time delay after avtrigger event.
Yes, I have the same problem I create a rule turn on flood light where another camera detect a person it turns on but newer turns off. I think wise team missing this settings . And I hope we will have this feature will fixed in a next update.
@tc10 mentioned that you can ask Alexa to turn on the lights on the Floodlight Pro for a specified amount of time. I wonder if that is possible for Floodlight V2 as well. If it works, then you can set a Alexa routine when it detects a person on your specified camera then Alexa will turn on lights on your Floodlight V2 for 3 minutes or etc.
we have had problem with deer in front yard.
at night after midnite till about 6am, if there is activity on my floodcam pro, in designated area, it turns on a Wyze plug. Alexa sees Wyze plug is on & turns on sprinklers (Rachio Zone 1) for 1 minute and turns Wyze plug off. This repeats if they stick around.
