Fix-It Friday - 2/2/2024
Hello everyone,
I apologize, we had many issues going on last Friday, so we did not get an update out last week. It is time to get back to our regular schedule of updates, so here is our Fix-It Friday weekly update:
:window: Forum - Wyze Cam v3 Pro floating window not working for everyone :window:
We have found that enabling Dark Mode causes the floating window to not work. We are looking into the cause of this and will have an update when we know more.
:cam_pan_v3: Core - Wyze Cam Pan v3 pan/tilt control issues :cam_pan_v3:
We are still looking for logs on this one. If it is affecting you let us know. Here is how:
In the Wyze app, go to Account > Wyze Support > Submit a Log. Select your device from the dropdown menu. Then fill in the description box with the date, time, and time zone of the most recent time you noticed this issue and a description of what’s happening. Make sure the Send Logs option is selected and then submit your log. When you have the log number, please post it and tag me so I can get it to the right folks.
:doorbell: Discord - Wyze Video Doorbell time stamp jumps around :doorbell:
We are looking into the cause of this. We will let you know when we have more.
:floppy_disk: Reddit - Wyze Cam Pan v3 microSD playback button is grayed out on Event Viewer :floppy_disk:
We are looking into the cause of this and could use some more logs.
- Let’s Take a Look at Some Previous Submissions -
:cam_v3: :cam_v3_pro: Forum - Video Playback stutters on Wyze Cam v3 and Wyze Cam v3 Pro when record sound is turned off in settings :cam_v3_pro: :cam_v3:
We are working on a possible fix for this. I will let you know when I have more.
:disappointed: Discord - Wyze Cam v3 not loading in group view :disappointed:
We are having trouble tracking down the cause of this and could use some more logs.
:arrows_counterclockwise: Core - Wyze Video Doorbell v1 notifications have images turned 90 degrees :arrows_counterclockwise:
We are still working on the fix for this and I will let you know once I know more.
:thermostat: Forum - Wyze Thermostat drops offline often :thermostat:
The engineers are still looking into this. I will let you know when I have a further update.
:floodlight: Reddit - No audio playback on Wyze Cam v3 when connected to Wyze Cam Floodlight accessory :floodlight:
Thank you for your patience as we continue to look for the root cause of this issue.
:vertical_traffic_light: Forum - Status light not displaying correctly on Wyze Cam v3 and Wyze Cam v3 Pro :vertical_traffic_light:
This is still in QA testing for a future firmware release.
:disappointed: Forum - Wyze Cam Pan v3 will not reconnect after it loses the connection :disappointed:
We are still looking into the information you have provided, I will pass along an update when I know more.
:house: Reddit - Wyze Cam Pan v3 does not return to set home position :house:
We released a beta that is a step towards fixing the waypoint drift issue. This beta will not change the current experience, but will give us some data needed to get to that point. Thank you for your patience.
:angry: Reddit - Event playback in the app is stuttering :angry:
As noted above, we have found a possible cause and are working on a solution.
:v3_spotlight: Discord - Wyze Cam v3 does not stay connected to the Spotlight accessory :v3_spotlight:
This is currently in QA testing for a future firmware release.
Thank you for reading! Have a great weekend!
Hi friends,
We have a callout today for new issues, so be sure to post and vote on any issues you are having so we can get these taken care of, until then here is this weeks Fix-It Friday update:
We need some more logs for this one since we are still unable to reproduce it internally. If it is affecting you, let us know. Here is how:
We are still looking into this one and as soon as I have more I will let you know.
:floppy_disk: Reddit - microSD playback button is grayed out on Event Viewer :floppy_disk:
We have located the root cause and are hoping to have the fix in the next app release.
We are still having trouble tracking down the root cause of this and could use some more logs.
We think we have a fix for this and are getting it merged into an upcoming firmware release.
This one should be resolved. Speak up if you still have this issue or we will remove it next week.
We have found a possible solution for this and are working to get it in an upcoming firmware release.
We have located the root cause of this and hope to have it resolved in an upcoming firmware release.
As noted above, we think we have a fix for this and are getting it merged into an upcoming firmware release.
Thank you for reading! Remember we have a callout for new issues today. Have a great weekend.
Here is a link to next months thread:
