Hi, everybody!
Thanks for joining us once again for Fix-It Friday! Let’s get started:
Reddit - No motion detection notifications on Wyze Cam v3 Pro when a custom detection zone is set
Thank you to the folks who sent in logs for us! We’re taking a look at them but could use some more. Here’s how to do to give us logs:
Recreate the issue. Then in the Wyze app, go to Account > Wyze Support > Submit a Log. Select your device from the dropdown menu. Then fill in the description box with the date, time, and time zone of the most recent time you noticed this issue and a description of what’s happening. Make sure the Send Logs option is selected and then submit your log. When you have the log number, please post it here as a reply so we can get it to the right folks.
Core - Videos are not uploading to the cloud
We are seeing improvement from last week’s beta firmware but not enough. So today, we released a new firmware build with further improvement. If you’re a beta tester, please test out the camera firmware this week and give your feedback in the beta areas! We feel optimistic about this build based on the data but really want your input.
Discord - Wyze Cam Outdoor image is not saving the rotate 180 degrees setting and it must be reapplied when entering the live stream
The Wyze Cam Outdoor Base Station firmware from last week is available again because it wasn’t involved with this bug. We have beta firmware for Wyze Cam Outdoor v1 and Wyze Cam Outdoor v2 releasing today. Beta testers, please keep an eye out for it and let us know how it performs!
Forum - Wyze Cam v3 Pro is not live streaming in the app properly during the day but works properly at night even without night vision enabled
We’ve identified a temporary fix for this but are still looking into the root cause. We’ve also confirmed that this is only happening to a portion of iOS users and not to everyone. We aren’t going to make it in time for the 2.38 app release but we’re aiming to fix this on 2.39.
Let’s Take a Look at Some Previous Submissions
Core - Cameras appear offline in the app, though they are online and viewable
Our hunt for microSD card logs continues! We have some and are taking a look at them. Thank you so much for the help! If you’re experiencing this and have a microSD card and a computer that can read the card, please send us a log to look at. Here’s how:
When the device shows offline, please take out the microSD card and wait a second before re-inserting the card (or inserting a new microSD card). The camera will then make two “ding” sounds usually within 30 seconds. On your microSD card, there will be a root or log folder with the device log that you can access with a computer. The files are named as xxxxx_log.txt. If there are multiple logs, select the most recent log file.
When you have the log, please email it along with a description of the issue and the date, time, and time zone that it occurred to:
microsdcardlogs@wyze.com
Reddit - Event recordings are skipping/stuttering
This is one of our top priority fixes. We’ve been making progress from our side but it isn’t finalized. For this one, there’s the stuff we need to change but we also have to work with our partners like AWS to fully resolve the problem. We know this has been an issue and we apologize for how long it’s been taking to fix it.
Discord - Cameras that are subscribed to Cam Plus Lite cannot enable person detection when a camera is in Wyze Home Monitoring
This actually was by previous design but we’re talking to the team about timelines for adjusting this. We think the earliest will be the 2.41 app since we’re still working on resolving issues with the Security Camera feature so it doesn’t make a lot of sense to fix this bug first.
Forum - Wyze Lock Bolt doesn’t auto-unlock when the “Disable during hours” schedule ends until someone manually locks the door again
It’s time to bring this back! We might miss the end of the year deadline because the beta hasn’t started and we’re going to have some blocked off time for software releases due to the holiday. But this fix is ready when the firmware is so we’re still in a good position!
Forum - Wyze Air Purifier Insights graph is not updating when expected
We are still planning this change for the 2.38 app and are on track!
Forum - Wyze Cam v3 microSD card playback is skipping the first minute of every hour (excluding midnight)
This fix will be in an upcoming Wyze Cam v3 release. But that’s still waiting in line behind some other critical bug fixes before we can tackle it.
Reddit - Wyze Outdoor Cam gets stuck at 1/3 without reset of the base station
We have the new Wyze Cam Outdoor firmware going to our beta testers today. Thank you for your patience!
And that’s a wrap! Thanks for joining us this week for Fix-It Friday. If you see anyone experiencing the issues above, please guide them over to this post!
