I would like the ability to order a wide angle or fisheye lens camera. The space I have in my kitchen is limited and the current cameras cannot see enough of the room to be effective. Instead of adding multiple cameras, one very wide lens would solve my problem.
I realize that there would be a trade off with image quality on the edges, but that is better than having no visibility there.
We be great for a wider field of view, from 110 degree angle to 140, 160, 180 degree angle. Is this possible? Can’t quite get a view at both ends of porch from window
I’ve ripped the front of camera and replaced front lens 4-5 times, These are very standard lens.
For the v3 I take a Dremel and cut a square around the lens, take strong pliers and break off the glue that’s been added, Then adding and adjusting another lens is super easy.
Make sure your camera is paired before taking off the lens, as you may have a hard time scanning a QR code with a blurry lens.
