Firmware 3.9.1.52 changes
Improved connection stability
Improved live stream stability
Fixed an issue with no alerts being received when the alert setting is on
Fixed an issue with local recording under ‘Record only mode’
Fixed an issue with occasional mismatch between MAC address and device ID
*Known issues (low probability)
  1. If your WyzeCam does not auto reconnect back to the network after the firmware upgrade, please unplug it from the power source and then plug it back in; it should reconnect back to your network.
  2. If night vision seems to be not working after the firmware upgrade, please use your Wyze app to turn night vision on and off once; it should start working again.
After update, I can’t connect camera. Please fix!
Did you try this?
What os are you running?
What app version?
Did you just upgrade to Firmware 3.9.1.52?
