A dedicated app for MacBook. Although the new Apple processors allow iOS apps to be used on the Mac, it crashes constantly when trying to review capture video on my Mac. I’ve been to the Web interface as well, but it’s somewhat limited.
I finally sprung for some memory cards and yes, using those chips makes for better captures and more consistent video clips, whereas through the online cloud captures much is lost.
It would sure be nice to be able to scrub through while viewing data on those cards, or
to directly access the cards through the camera, rather than having to climb the ladder and pull the cards out of the cameras in order to directly access the clips. I do love how they’re Categories are broken out by The date, hour and separate files for each minute. That’s cool and makes it easy to find stuff. Sure it would be better if we could do that without having to remove the chip from the camera.
I would like to see the ability to tap on the timestamp in the SD card timeline and select the hour and the minute we need to see. It was there before one of the recent updates, and now it’s gone. That was extremely helpful and it would be awesome if you guys could return that ability!
FWIW, I believe that several (if not all) of your suggestions have been requested in existing Wishlist topics, so you can search the Forum and add your votes and comments to those to show your support for those features.
Incidentally, there was a recent topic from Wyze that might be of interest:
Spring is here, and so are the birds! You could link some of your robin videos into that, too. I’ve enjoyed seeing those.
Thank you!
We are enjoying using these cams as Bird Cams.
Getting some amazing shots!!
