I recently purchased the Wyze Battery Camera Pro based on the advertisement that it records directly to an SD card when offline to catch someone vandalizing my property, I was disappointed to learn the feature didn’t capture anything, even after trying the AI trial detection feature. Why state the camera does not need wifi for recording?
The motion detection does not work if not connected to WiFi. The online Google reviews were incorrect and must have been altered, judging by the many users on this forum with the same complaints. I would much rather save my time and energy on a different brand that actually works and listens to its consumers.
I don’t know about the Battery Cam Pro but the WCO v1/v2 battery powered cams will record to the SD even if off line as long as you have Scheduled Event Recording Set. I have four old WCO and have recorded to the SD for years using Scheduled event recording, set for 30 days, no cooldown period, events only with a max video duration of 5 min each video. Does the Battery Cam Pro have Scheduled Event Recording setting on the app like the WCO ? You can do cloud recording and Scheduled Event Recording at the same time (On the old WCO) , no idea about the BCP.
It will record without internet, but with some cam models, if they’ve been offline for more than 30 minutes, they’ll reboot to try and get back online. After that happens, the date/time is no longer correct (assuming they didn’t get an internet connection back) so you have to either pull the card and find the folder with the old date (which is where it will record to) or navigate through the calendar in the app to find that date. I’ve heard it is the date of the firmware build.
Unfortunately, these cams really aren’t meant to be used offline and there will be limitations if you try to use them that way. Smart detections will not work at all and no events will be recorded (smart detection requires internet) so you wouldn’t want that enabled.
