Event Time Line Scrolling
I want to suggest (we need this as soon as possible) that the “Event Time Line” should be able to be scrolled a whole 24 hours at once. the ability to quickly find a video recording is essential to be able to catch the bad guys. Because as it stands now it takes me 10 or 20 swipes to just get from 12 midnight to 10 pm. and then to top it all off when I select an event to look at it jumps right back to 12 midnight to start all over… This is totally unusable like this…
If you would like to request that Wyze add this feature, that is handled thru a new topic post in the Wishlist. Go to the Wishlist, search the topics for one that matches your request. If you find one, vote for it at the top, like :heart: some posts, and add your reply post to support the request. If you do not find a match, submit a new topic for approval.
I don’t understand what you mean. Are you saying each camera should be able to be scrolled a full 24 hours worth of its recorded video? Instead of having to look at each clip separately?
