Searching for Events for a given hour is impossible
I have dozens of events in an hour.
If I am looking at a prior day’s events, it takes an innumerable amount of swipes to go to the morning hours.
Please add a filter by hour so that I can go to 2 AM.
Of note - that is the time when someone broke into a neighbor’s car, so I am trying to get footage from 4 cameras. It is impossible to do on phone, and you can’t download om my.wyze.com
Are you talking about SD card or cloud?
I not familiar with the interface for cloud/cam plus but with the SD card you just use the timeline to go where you want. If you aren’t doing continuous recording, you can use the arrows to jump between events too.
FYI this forum isn’t for requests, Wyze will likely never see it. You can add it to the “wish list” forum but honestly things don’t really seem to gain much traction there unless they get thousands of votes.
If your talking about cloud events, you can “close up” the different hour blocks of cloud events by clicking on that hours header. That way you can shift through them faster to find the hour blocks your looking for.
Make sure to keep swiping up from the bottom to keep loading more events for that day (as 20 are loaded at a time).
There is this following Wishlist that you can vote on that appears is what your asking for.
Yes, unfortunately, cameras can have lots of events, so the scrolling is incredibly slow, sometimes 10 minutes of scrolling.
Worse, when you minify 11 PM, you still have to scroll many times before seeing 10 PM, let alone 2 AM.
In any case, I’ll vote on the other thread, since it has been the single most sore spot of an otherwise great product. (used over 4+ years.)
Ok, I found a workable solution on Wyze Web Events
It isn’t super obvious, but if you filter for a specific day, then you get the option to filter by time:
