Event selections
This is my first time on the forums, so please forgive me if this has been posted.
I would like to be able to select multiple recordings events to delete at the same time. I use my grill a lot and go in and out of my house and get tons of recordings. Right now I have to click each event and wait a few seconds for it to load, and then I am able to delete the recording.
I would like to be able to select multiple events and delete them all at the same time. Much like you do with junk email. I like for my event area to be clean. I only save the clips that I need to. Thanks!
Welcome aboard! :slightly_smiling_face:
On the newest version, the pencil icon in the upper right corner of the event screen should bring up the check boxes. On older versions it will be three dots in the upper right corner.
Thank you! I did not know this. This helps me a ton. Thank you once again!
Glad it worked! :smiley:
