After todays (6/11/20) app update it appears that the only way to delete events is to do so One at a time. I have not found any info about whats new in this update. I have three cams
and each one might have as many as 300 events. Anyone know how to delete events
like the app used to do?Thanks
When in the events tab, tap the pencil n the upper right, select the ones you want to delete, or hit select all, the tap delete in the lower right.
That was easy. I never checked the pencil, I thought it was to write with.
Thanks
