So I’m not sure if I’m missing something. I’ve seen mixed answers. Is the outdoor camera not capable of recording 12sec clips to the cloud when it detects motion? I see some say it does and others say it doesn’t. I’ve had mine up for a couple days now with no events triggered and no notifications either and yes notifications are turned on.
My Outdoor cam is not saving 12 sec events to the cloud.
I have 6 other indoor cams that work great but the outdoor does not save events for me to see in the app.
I tried the SD card in the base, then Inside the outdoor cam, and still doesn’t work.
I tried notifications on and off.
Detection zone is set to where I walk, nothing.
It recorded two events one day during inside testing and hasn’t done so since.
You are not missing anything. Basically the damn things aren’t working as advertised. (Or at least as I expected them to. Sometimes I miss Wyze’s fine print)
My WOC is faithfully taking a jpg picture every time something wakes up the WOC PIR sensor.
I guess Wyze determines what is an event and what gets recorded. When my WOC occasionally gets Wyze to record to the cloud, I do get a 12 sec clip. that arrives many mins or hours later. There are too many different forum posts on this subject for there not to be a major problem with the WOC. Perhaps Wyze could educate us and tell us how they really work.
After last update, about a week ago, my WOC no longer sends the 12 sec rec to the cloud. It just takes a picture. Can’t find tutorial to activate the original settings.
