I have three V3 cams that worked fine for months. Now two have lost connection. When I reset and attempt to reconnect I get an error, “Can’t identify specific network.” What can I do to get these cams operating again?
Be specific. Where or what are you trying when you get that message?
Also note: the SSID is case sensitive. So when you set the SSID and don’t match the case, nothing will connect either. At least on some routers
