Connecting cam v3
When I try to connect my camera it says “cannot find the specific network name”. Help!
Put you phone on your 2.4ghz. Then set the camera up
Have you changed your Network name on your Router or changed your router? the SSID is case sensitive in some cases.
you could go through the setup again on the v3 without removing it from your app to establish the WiFi again. something to try.
I have the same issue. Camera v3 was working fine prior to relocating. I’m 10’ away from router.
