I have four windows that are designed in a way that the stock bar that comes with the sensor won’t work. With my current sensor from Brinks, the installer used a flat bar. Has anyone had to do this or have any suggestions?
Try a flat magnet. It should work.
I had seen that and wondered if it would work. Thanks for the confirmation.
Ken
