Easy to switch from Doorbell Pro to new doorbell camera?
Hi all. Doorbell Pro has worked well except for once in a while missing or cutting off visitors. Tempted to upgrade to get SD card so it’s always recording but I am not bothered enough to want a lot of hassle. Can I just unhook the old doorbell and wire in the new one - are they the same size? - and use my existing chime? Thanks
Not the same size but sh/be able to measure and drill a new hole in the mounting plate as I did when I moved from the dbv2 to the db duo.
Existing house chime or db pro chime? No, for the db pro chime. Yes, for house chime if you have the proper voltage transformer and the db v2 chime controller that works for the db duo and now sold separately on the Wyze shop for $17.99. Or use the wifi chime that comes with the duo.
