My Video Doorbell Pro is not accepting a charge. It’s been in use for less than a month. The firmware is all updated. The firmware version is 1.0.64. I’ve tried two different cables and two different chargers. Support just sends me “how to unmount and charge” instructions. Any thoughts? Ideas?
I am assuming this is using the chat tool?
I would contact support via phone.
Contact Us – Wyze
I have the exact same issue with my doorbell pro. Any resolution?
I’ve had mine 6 months and it’s has been charged twice after receiving low battery notifications but now it won’t charge or turn on. And I didn’t receive a notification saying it was low and needed charging. I hope it’s not dead. Anyone answering this thread yet? Thanks.
First time charging the Doorbell Pro and now it won’t turn on. Anyone found a solution. I’ll reach out to Wyze though. Kinda disappointed TBH
I got the doorbell pro a couple of months ago it charged up fine first time now after a recent firmware and app update it will not charge. I have several chargers that I’ve tried it with. The ring around the button goes solid white but when I check in the app for battery charge it never changes and the on off button on the back does not seem to work. Did Wyze get a bunch of bad batteries or something, cmon guys fix this I gave up a competing doorbell product that was not as nice but at least it worked for your product because I’m trying to go all Wyze in my house and this is how I’m rewarded for my loyalty. I just bought this thing, might even still be able to return it at the depot. This is very disappointing for sure.
Same thing happened to my doorbell pro. I reached out to support and they sent me a replacement well 6 months later same thing has happened to the second doorbell. I think i’m going to have to switch to another brand… I’ll be reaching out to support again to see if they will send another one. This is ridiculous…
My two cents, they got a bad batch of batteries. It would be nice if the batteries were easily user replaceable but that doesn’t appear to be the case. If you know what you’re doing you could probably change one out IF you could get your hands on the proper replacement battery.
I hard wired it and it’s working. Just can’t use it wireless… Bad batteries is def the problem!
Would anyone with a Doorbell Pro which has a dead/non-charging battery be interested in parting with it? I would even pay shipping.
My doorbell pro has stopped charging after two successful charges in the past.
Wyze needs to acknowledge there is a problem and help their customers, this is not acceptable.
Mine from day 1 has said Battery not installed in red underneath it in my list but I’ve had it hard wired and it seems to work so I just ignore it. It’s annoying but after having my doorbell v2 fail which prompted me getting this one I’m not in the mood anymore. As long as it keeps working while hardwired then I don’t care if the battery is defective. Now if that suddenly starts being a problem and I suddenly need to deal with it not working because of it then the next step is a hammer unless of course it just melts since it’s been blasted by the scorching 120° F temps for the last week and a half and it’s just getting hotter out.
Same here ; my doorbell pro’s battery would not charge at all even after charging it outside the camera so I hooked it up to a 8.5 volts dc transformer using the two screws behind the camera (not the micro usb) and soldered it there … Now the reception for the chime and the wifi is at the maximum while it was at 2 bars with the battery alone . note that it will turn on by itself only after reaching 8 volts or so , it will not turn on under 8 volts !
This topic was automatically closed after 30 days. New replies are no longer allowed.
