Don't see my order in my account
Hello all, I need some help here please.
I logged in my account to check the status for cam v3. I couldn’t find it anywhere.
I placed it on 10/28 and Wyze charged it same day.
Thanks any help.
Hi @t.tran.usa Sorry you are having this issue. The first step is to open a ticket with Support.
Live support is available: +1-206-339-9646 Monday - Friday 5 am - 6 pm PT Saturday 8 am - 4 pm PT. This should give you a quick resolution, but you can also reach them online at Wyze Support.
They are busy and it may take some time to get a response. Once you do either way you should get a ticket number. Keep this and if you can’t get resolution post back here with your ticket number.
Had this happen to me once with another order a while back. Turns out, I hadn’t been logged in when I placed the order. I contacted support and gave them some info about the order, and they attached it to my account so I could see it. Might be a similar issue.
Thanks for that! Hopefully Support will straighten this out.
I had the same problem, but my order still appeared on my porch. So check with support, but don’t worry too much in the meantime.
Thanks for your reply.
I got very quick response from Francis (Wyze) and still trying to solve the issue.
Issue has been solved.
Thanks Wyze team.
Thanks for the update
