I just received my WYZE camera and am very impressed! I’m thinking about making an enclosure to fit under the eves for an outdoor view of my front door/driveway. I’m envisioning a small plywood box with a plexiglass front that would allow for adjustment of the camera’s view. Do I need to be concerned with ventilation of the electronics? I think a few holes drilled in the bottom and top/sides would be OK (I’m in a coastal marine climate - not hot). I could paint it to match the house and use some window screen material to help keep the bugs out.
edit: I should have mentioned also that I leave my porch light on overnight and haven’t yet checked to see if the lighting is sufficient to have the night feature on/off or auto.
