Disable hub ding every time a door or window is opened/closed
Is there a way to disable the hub ding every time a door or window is opened/closed? I have looked in hub settings and the entry sensor settings to no avail. Am I just missing the setting or is there not one??
Only if you have the Home Monitoring Service. It’s called “tunes.”
Thank you!!!
