Device History
Can anyone tell me where to find device History now with the latest software update ?
If you mean Rules History, tap Automations, look for house/clock icon upper right.
@Seapup
Thanks Seapup. That’s exactly what I was looking foor :+1:
Would you happen to know thew answer to my post yesterday asking how to sync time on a wyze switch ? Cheers,
I saw that post and looked for a way to sync on my Switches. I can’t find a way. I assume this is related to local Switch schedules? And how are you syncing Plugs?
@Seapup
Upon reflection I see that I can’t sync time on plugs either. Only cams
Are you trying to sync because local schedules are off by x hours?
@Seapup
Only reason I wanted to sync, like I do on occassion with cams is to get a couple of my switches to go ON and OFF at same time. They were off by a few minutes. I’m handeling this by setting one of the switches to go OFF 3 min before sunrise to match the other which is set to go OFF at sunrise.
The only thing I can think of is switch your local schedules to cloud-based schedules, or vice versa. Local schedules are at Switch > Settings > Schedules. If that’s where you created your schedule, toggle it off (or delete it) and create the same schedule in the cloud under Rules (2.50) / Automations (3.0). If you have multiple switches, just list them all under Action in one cloud-based schedule.
Thanks, I’ll try that
